RE: 3DFoamy.com SU 26 MX
Hey there, I'm working on putting together the Su26mx from 3dfoamy as well.
I was wondering if the added side profile helps with wing rock in relation to the main fuse? I had built the Sukhoi from foamyfactory but the wing and tail wobbled so much I put diagonal bracing between them, I was wondering if I needed to do the same with this one?
Also, are you guys flying two aileron servos, and if so how are you attaching them? (sinking them in, or surface mounting them on the bottom.
I'm covering it with a pretty light vinyl decal material, and it looks great. I'll see if I can get some pics on here.
