RCU Forums - View Single Post - Engine Woes
Thread: Engine Woes
Old 06-24-2002 | 01:47 AM
jack2 pratt
Default Engine Woes
filter your fuel mine is in the pump line try cleaning needle valve and carb where the fuel goes through if nothing works remove the head and ck the cyl for peeling look for brass at full th. quick pinch and release the fuel line adj the needle so you can hear the rpm increase 2 or 3 hundred ck all fuel lines for cracks hope this helps jack
