Throttle Cable
Just curious what you guys are doing for your throttle cables.
I have been using your basic yellow nyrod with braided cable back to an easy connector on the servo. At the throttle end, I'm using a threadded nylon ball link.
I've noticed with the longer cables (Servo behind the TE of the wing), and the cheaper small servos (Hitec 85s') were using on throttles that the barrel is not always centered. Also, with the long cable, the weight is a bit more than I like.
Any ideas??
