RCU Forums - View Single Post - CG Super Chipmunk and side-mounted OS-91 Surpass II -- FG Cowling woes
Old 04-12-2004 | 02:14 PM
apalsson's Avatar
apalsson
Default RE: CG Super Chipmunk and side-mounted OS-91 Surpass II -- FG Cowling woes
If the engine head is reasonably close to the cowl, it may be possible to bolt the muffler on after the cowl has been fitted.
I do this on a similar sized plans I have where cowl space is limited.
I simply cut a hole, big enough to slip the manifold through and get a spanner in to tighten the locknut.
Would this be possible?
