RCU Forums - View Single Post - 3DFoamy.com SU 26 MX
Old 04-12-2004 | 06:52 PM
FNG's Avatar
FNG
Default RE: 3DFoamy.com SU 26 MX
ORIGINAL: raabid
I was wondering if the added side profile helps with wing rock in relation to the main fuse? I had built the Sukhoi from foamyfactory but the wing and tail wobbled so much I put diagonal bracing between them, I was wondering if I needed to do the same with this one?
Also, are you guys flying two aileron servos, and if so how are you attaching them? (sinking them in, or surface mounting them on the bottom.
No bendy twisty airframe hear, its pretty darn solid built per the plan.
I surface mount all my servo's except the aileron servo, Use hot glue and stick them to the vert and hort parts of the fuselage.
I ran 1 aileron servo, cut out the fuselage and mounted centered. The trick is the pushrod angle is extream, so if you dont want a Whole bunch of differentail aileraon through (more down than up...) you need to use a "X" servo horn and use the two forward arms, position the servo and aileron horns so the rods are at 90 degrees to the servo horn arm. Worked good.
