RCU Forums - View Single Post - Sig Somethin' Extra
Old 04-13-2004 | 06:39 AM
Irish R.Seer's Avatar
Irish R.Seer
Default RE: Sig Somethin' Extra
Very easy to build and goes really fast (the build I mean). The only thing you should be careful with is how you hold the two wing halves together, the kit uses rubber bands, but I had a problem with mine so I installed a Dubro turnbuckle with a small ring on each end to go on the J hooks.
good luck with your SSE I had a ball with mine.
