RE: How to kill an engine ?
I usually use throttle cut when on the ground. But I also have an ignition cut on the Tx in case of emergency's.
No other ways to stop one unless you go to the throw your hand, foot, rag, stick in the prop OR just pick the plane up by the tail and let the prop hit the ground. [>:]
All kidding aside. If you can, rig your plane with both.
