RE: I am unsure about flying this
I think the black wire you saw has "black creep" from a bad nicad. If this is the case the wire is bad. Don't use any of it. If the wire is all black colored when you strip it back it is bad. I'm pretty sure that indicates the nicad pack is shot also. Cut open the other packs wrapper and inspect for crystalization. I had a pack that was bad like that. It had black creep to.
