RCU Forums - View Single Post - Engine gremlin?
Thread: Engine gremlin?
Old 07-13-2002 | 08:46 AM
bgorham
Default Engine gremlin?
Problem sorted. It was the bent needle valve assembly. I actually did an upgrade on the needle valve and seat/oriface. On the Irvine .40 that I have, there is no type of gasket between where you screw the needle and mixture control and the seat fitting. The Irvine .46 and bigger engines have a notch with an o-ring on the seat assembly. I installed the new one and wala .. all problems solved.
Thanks all for the help
Bo
