RCU Forums - View Single Post - incidence angle variation
Old 04-13-2004 | 08:21 PM
scottfl78's Avatar
scottfl78
Default RE: incidence angle variation
well 1/4 degree and 1/2 degree are pretty small and you will be ok to fly it... If the manual states 0 degrees then that is what you want... You will be able to fly more more precision with perfect incidence... Whether it is a kit or an ARF you may need to do small modifications to whatever part is out of incidence to get them all straight... I can't speak on this plane though because I don't have one... Engine may be easy to fix with tiny washers under the top 2 bolts of the motor mount bolts to bring it online... If you want specifics on how to fix the wing incidence take a profile picture of the wing mounting and we will be able to help you...
