RE: BME110 and cans
Wood- The cannister set-up "kinda" acts like a super charger through pulse waves. You will get a denser fuel charge into the combustions chamber, denser charge higher compression pre ignition with low octane. If the needles are set to low you will have a lean condition, carb not being able to supply enough gas for proper fuel air mixture. Somebody else can x-plain it better I am sure.
