RCU Forums - View Single Post - Throttle Cable
Old 04-14-2004 | 10:25 AM
bob27s's Avatar
bob27s
My Feedback: (19)
Default RE: Throttle Cable
I usually use an .040 solid music wire running through a nyrod tube. It will handle reasonable routing without binding.
I solder on a threaded end for a dubro ball link.
Served me well for many years.
I have also done the throttle pinch-off using a "U" shaped end on the same rod, and pinching against the firewall or backplate mount. But expereince showed that I was much better off using the carb to shut the engine down.
Bob Brassell
