RE: GWs A10 EDf55's
Hi,
With throttle management i hope to have lot of flights (if not crashed) with the stock motors.
In case of burned motor you have to find the small hole in the fan, open there a small hole for the allen key and unscrew the two allen screws. Then try to remove the impeller (it is very tight in the motor).
Two small screws and remove the motor.
Hope it helps.
I'll send photos
