RE: 1st plane questions???
While it's no a big problem, if you're like me, it will bug you. here are a few things you can try:
First, if you have a heat gun, carefully bend it the other way and apply heat to both sides.
Or, try putting a thin shim under it and weighting down the ends (ecentially bending it the OTHER way) and let it sit overnight.
But, as said, if neither works, don't worry about it.
