RCU Forums - View Single Post - spark plug getting adequate spark?
Old 04-15-2004 | 05:46 PM
Zorak
Default RE: spark plug getting adequate spark?
i opened up every part of the carb and blasted all the holes with carb and choke cleaner. when i crank it, im opening the throttle all the way and plugging the choke. i have the high and low adjustment screws seated and then backed out 2 full turns.
would the engine fire once if i sprayed the carb and choke cleaner right into the cylinder and then sparked that by cranking?
