RCU Forums - View Single Post - GP CG Machine = Junk? UCD 60 Problem
Old 04-15-2004 | 06:45 PM
AcroJo's Avatar
AcroJo
Default RE: GP CG Machine = Junk? UCD 60 Problem
Thats the problem. The spread is not wide enough for the UCD. You gotta go to the first rib out in either direction. Longer spreader bars are needed, or if you have a board, you can measure the stance needed to put you under the ribs and just screw them down to the board. The CG machines are acurate, but the arms are floppy. Joe
