Hi Turbine Guy
The thrust level for the TJT-3000 is misquoted on our website and is scheduled to be fixed in the next edit. Its just a bug that slipped through he cracks... The ~34lb spec is the military specification, not for sale to the R/C community.
The correct specs are listed below.
Kelly
Note: as of Dec 2002 these figures have been revised to include continuous operation at 126K RPM @27.5lb.
KW
TJT-3000 Specs are as follows:
Maximum Thrust:
27.5 lbs. (12.5 Kg) @126,000 - continuous operation
Residual (min) Thrust @ idle:
1.2 lbs. (0.55 Kg)
Max Permissible Shaft Speed:
126,000 RPM (max 2 minutes per engine run)
Max Continuous Shaft Speed:
120,000 RPM (entire flight)
Idle Shaft Speed:
32,000 RPM
Max EGT:
640°C
Case Pressure:
2.10 Bar
Fuel:
Kerosene, Jet A1
Start Fuel:
Propane
Oil:
Mobil Jet 2, Exxon 2380, Aeroshell 500
No substitutes, (2-stroke oil is NOT permitted)
Fuel - Oil Mix Ratio:
20:1 or 5% oil added to fuel volume
Fuel Consumption:
14 oz/min at 27.5 lbs thrust
Dimensions:
4.5 in. diameter, 9.5 in. length, 12.0 in. length w/electric starter motor
Weight (turbine/E-start/straps):
3.6 lbs. (1.65 Kg)
Turbine Wheel / NGV spec:
66mm Ø, manufactured by ArtesJet / TJT
Engine Color:
Polished aluminum casing, Red front cover
Polished aluminum electric starter
