RCU Forums - View Single Post - Breaking in the O.S. 46 AX
Old 04-16-2004 | 01:46 PM
Bax
Default RE: Breaking in the O.S. 46 AX
If you don't run your O.S. Max .46 LA at full throttle during the breakin process, you won't get it broken in and you'll have an engine that will likely have a much-reduced service life. The main caveat is to not run it in "four-cycle" mode.
You can always tell if you are rich of peak by the fact that a quick pinch of the fuel line will give you a jump in RPM.
Please check the O.S. FAQ page:
http://www.osengines.com/faq/product-faq.html
