RCU Forums - View Single Post - Engine Won't Start
Old 04-16-2004 | 04:08 PM
wolfie_taw
My Feedback: (15)
Default RE: Engine Won't Start
well the fuel tank is set to as low as it can go because it is on the floor of the plane now with no padding under it. I will keep you informed on what happens when I take it someone experienced to work on it. Thanx for trying to help me. Okay, there are two screws one is right next to the air intake area and the other one is next to the throttle arm. I don't know if they need to be set to a certain area and if that could be the problem that they might need tightened up or loosened.
