pull pull
It is just as important to make sure that the servo is enough to do the job but for the cables ss fishing line or dubro cable is what I use and I try to keep the linkages to a minimum(simple) I like to pull test knots by hooking them to a horn attached to a rafter in the celling and standing on a bathroom scale to see how much weight I can lift off pulling on the cable 2Xthe weight of the airplane or to the test of the line is easy too achieve. and it show es you that the not will not pull out If I think of it when I get home I will take a pic of how to tie the knot
