RCU Forums - View Single Post - Own design problems
Old 04-16-2004 | 09:29 PM
  #33
Tall Paul
Default RE: Own design problems
"...vertical dive..."
That sounds like you're holding elevator for level flight.
A trimmed plane can't know whether your fingers are on the sticks.
In the real world "stick-free" stability is a testing criteria, but with our models, the servo holds the surface so the plane has no genuine "stick-free" mode.
Are your ailerons aligned along the true chord line of the airfoil?
If the aileron trailing edge is down relative to the zero chord, it acts like a flap, which increases the nose-pitch.
