RE: ABS Cowls and Wheel Pants
I tried this,,,
On a pod for a Seamaster 40-
and it works GREAT!! it takes awhile to set completely on the thicker parts, but sanding is easy, you can control the 'thickness' by letting it stand or adding more acetone. I used "layers" to build up the gap formed by the seam and you can't tell where it joined!!
thanks for the tip!
