RE: prop tracking problem
I agree with FHHuber, sounds more like a bent shaft.
A quick easy way to tell if the shaft is bent is to get a long piece of brass tubing with an ID barely larger than the shaft. With the prop removed, slide the tubing over the shaft, remove the glow plug and turn the motor over slowly. The free end of the tube will exaggerate any misalignment of the shaft.
