RE: Phoenix Models Giles 202 question
Personally, I wouldn't recommend flying it without the recomended CG. 7.5 oz of nose weight is a bit much. I'd try to move everything forward including the engine if possible to try to get it closer. If you have to, a heavy prop hub may get you where you need to go.
