RCU Forums - View Single Post - Seagull PC9 trashed
Old 04-18-2004 | 12:51 AM
SunShyne's Avatar
SunShyne
My Feedback: (68)
Default RE: Seagull PC9 trashed
ORIGINAL: polar bear_909
Cool photos. Good to hear that you have had that many flights. I was getting concerned about the frequent negative feedback on the forum about the PC-9. Is it worth strengthening the block where the wing screws go into and is worth replacing those screws??
How about replacing the dowel pushrods with good ones, a must?
By the way did you use the fuel tank provided? and if so what's the flight time?
I didnt do any strenghtening at all, I replaced the supplied wing bolts with dubro's and I used the stock tank and get an easy 15 minutes with decent throttle management.
matt
