Spur gear problem
Just put a new spur gear in the beast, and after all of about 10 minutes runnings, the teeth on it are all slightly bent over. What's causing this? Is the clutchbell too tight, or too far from the spur, or could it be the clutchbell teeth being worn? I don't want to be going through spur gears on a daily basis. Thanks for the input.
Jag
