RE: U Can Do 46 and 60 prop/rpm
Amen to that Joe. I am having so much fun with mine with no dead sticks I bought a new Saito 100 and a Cline for a back up, I am looking at what is coming down the road In Arfs to install them. THE EXTREME FLIGHT 540 Edge 60 size will be on the market soon. As well as the Sig Mayhem ( NOW) may be a candidate for it. I like to see one preform first. OMP Yak 54 Is what I may go with. I may have to build the Yak only to match the weight of the U-Can -Do. Joe after 2-3 hours engine running time make sure you adjust the valves and give it a good wrench check out to make sure every thing is still OK. As well do it now ( NEW) and I bet you will find a motor mount loose. Or muffler that may need new Nylon tape installed. Just remember if you loose a carb screw or something on the engine - the turn around time to get one may be two to three weeks with Horizon. I may have to try and balance my tru-turn spinners because of you And see if I can get it true thanks . I may be asking you a few questions if I am doing it right? Seems like a plan. SL
