RE: Biplane Trainer
I agree with Norm... a biplane can be a joy to fly. But! It takes some time to get it set up just right. If you don't have the CG in the right place and the wing incidence just right, you'd definitely be finding a new home for your engine if you're lucky. Definitely have someone experienced help you with the first flight. I wouldn't limit the throws too much but use dual rates to limit it first.
Good luck! And when you're up for the first time yourself, remember to have a spotter. That thing can play tricks on you. Can't tell if it's right side up, going toward or away from you. A spotter, that knows what problems you may encounter, can really help you out.
