RE: Mid range problem
Are you guys running the same muffler combination? In other words, if both using the same muffler, have you removed the baffle, drilled out the exit hole, or? I have the XLS .52 myself and it is pretty new, so I am interested in this thread and the outcome. I'm thinking that the engine could be sensitive to tank pressure as well as having a very sensitive low end needle adjustment......
Ernie
