Ernie good point... I'm running the stock muffler, stock exit hole baffle removed. I've tried it with the baffle in no difference[
] I've also played with tank height, I could make it run worse but not better, right now the tank center is just a hair lower than the HS needle... I've also ran remote needle valve from day one, no air leaks so I don't think thats a problem.
John
