Servo reversing
It really isn't that confusing once you're used to it, but if you switch it around, no one else will be able to fly your plane that way. If you start flipping the reversing switch back and forth so someone else can help you with the plane then sooner or later you will probably get confused and take off with the elevator backwards (which is not good)
