RCU Forums - View Single Post - What is the trick?
Old 04-19-2004 | 02:44 PM
DesignMan's Avatar
DesignMan
Default What is the trick?
I need to be able to start my diesel without touching the compression or needle setting. The reason for this is that in Control-Line aerobatic competition, you are strictly limited on your run time, and can't use a shutoff timer or servo. You have to achieve really consistent runs with just the load of fuel in your tank.
How do you get the engine started and up to temp. without touching either the compression or needle?
