RE: Sterling Puddle Jumper 1/2 A RC Air Boat, anyone got one?
I built one of these in 1976. I remember the patriotic decals that came with the model.
I used a Cox engine with an aircraft firewall motor mount and a large external fuel tank running into the hollow stern of the boat. It drove on land exactly like a tail dragging plane. I would run the puddle jumper on a black asphalt street. I had to replace the small diameter rear wheel every ten or so runs, because it would wear out the rubber. It was a real pain waterproofing the front wheel wells, especially around the axles, yet have the wheels easily replacable.
It ran very fast on asphalt, once it built up momentum.
I did not do anything to the ABS hull. It ran fine and survived countless head-on collisions to the cement curb.
When running on water speed wasn't as dramatic. I had to add balast to balance the boat in the water.
The instructions in the box did not mention rigging a throttle to the engine. I used a bent airplane linkage rod that went under the fan shround, and behind the Cox cylinder throttle coller.
Flip-starting the engine was a pain, trying not to break the balsa/plywood fan shroud.
Probably the strangest model I ever built. It did last a long time though. It actually lasted longer than any other plane, boat, or car I ever built. It was still a functional model when I had to throw it away.
