RE: www.Learning 3D step by step - 2
Vittorio, there is no solid answer for this question.
You will use only rudder to steer the plane and to make most corrections.
You will use ailerons, in combination with rudder, at times to make corrections for extreme attitudes.
Attempt to keep wings level durring harrier regardless of which control surfaces you use.
