Balsa USA Enforcer, HELP?
Thanks for the reply and comments. The reason for the high AOA was I had guy tell me that it was needed with this airplane in order to get it to rotate easier. The gear did look to stiff so the rear gear got bent back enough so there is a little spring to it plus its one of the ways it got that AOA. The reflex is mystrey to me and the reason for it but thanks for the reminder. I almost wished I had gone the elevon route. I already have plans on building another next year once I determine if I like this or not. I want retracts as this kit looks sleek with no gear. Your right about the props. I orgianlly mounted a 91 but didn't want to put a 14 x 6 prop on it because of ground clearance and the next smallest I could find was a 12 x 6. Thanks for the info
