ORIGINAL: Rick Sowell
Deputydog and Joe: you guy's are right on, these other guy's just wont listen to you. this problem will go away! I switched to Amsoil at 100:1 and adjusted my needles and it went away completely. how many of us will put 4-5 gallons of glow fuel through a motor before it gets reliable, why can't a DA take that many also? mine a three turns out on the low end did not sound rich in the air, these things will burn all the extra fuel you can put through it and not quit. good luck you other guy's Rick
I hope I'm not being lumped in with "these other guys" since I didn't complain about my DA 50. I only offered a sugestion about oil mixture. I haven't run my DA 50 yet. It's still in the box it came in just before Easter break. That said, I will keep the needle adjustment recomendation in mind if my engine does start quitting when stopped abruptly.
Wiz
