RE: 783 delta wing setup question
Hello Danny - my responses below...
Check to be sure the distance out on the arm is the same on both, and that the distance from the hinge line to the attachment point on the control horn are equal.
<<Did that - they are absolutely identical>>
Also be sure that the travel adjustment values are close to each other.
<<Brand new setup - they are also identical, DR's are set identically, etc>>
If they remain different, it may be a difference in the servos.
<<I'm using identical servos, but I also swapped servos and there is still a rather large difference>>
You should be able to adjust it out through travel adjustment and dual rate adjustments to get the throw desired. (Use travel adjust to get the throws equal, then use the dual rate function to increase or decrease the total travel of both.)
<<I can 'make' them kind of ok, but my question had to do with why this magnitude of difference exists in the first place. I'm trying to say that the fact that delta wing was selected, it is looking like there is large bias in the mixing that should not be there. Can you confirm?>>
Thanks Danny!
..AJ
