RE: Help for the new 3D Guy . . .
I don"t have this plane... I do have 5 profiles though. your 53 will fly this plane well unless it's VERY heavy... average is 5Lb. you would be ok up to 5.5 IMHO power wise, anything over 5.5 will hurt hover pull out. Your prop selection is not bad... if your 53 turn's the APC 13x4W then run it...it should handle it, if your lacking the R's then try an APC 12.25x3.75, either prop should be a good match for your engine.
John
