RE: Action Shots
Hello again Sandeep,
The lateral control hinge is made from .032" P/P.
The hub is made from .060" fiberglass circuit board material. It is fairly rigid.
The aft tilt is 10 degrees and the engine downthrust is 4 degrees.
The pitch control is obtained from the elevator just the same as most other aircraft.
Good luck on your conversion! There is a wealth of technical information that will help you if you will look up Jim Baxter's site at autogyro.com. You could also try gyronuts.com as another good source.
Regards, Joel
