RE: Phoenix Models Giles 202 question
Wow, just removed all that trim on my radio so I can adjust it via the servo linkage. Don't know what happened to my center, but it was off. That was why I had to trim it so much. But it still requires some up trim to fly straight. I would still like it to be perfect, so I look forward to see Kaz's setup on his G202.
Had a friend look at my possible incidence problem (eye ball) and he said he couldn't see anything, instead he found the engine to be pointing down a bit like scar said to check.
Will see how it flies on Saturday. If is still has a problem we will check the incidence again w/ a meter that a club member has.
Mark
