somethin ****ed up..........
ok..... what are the chances that you have the only engine we have all seen that runs exactly backwards of all of ours? And you also have a reverse pitch prop?????
This airplane wouldn'y be a skymaster would it? with the (pusher prop) prop in the rear of the plane??????????
Call me crazy, but something here just ain't right. Yes, there are some engines designed to run clockwise. These are for specific un-orthodox installations. get this..... if it indeed were designed to run clockwise.... you would need a special reverse pitch prop, no? Compare it to all the other ones in the hobby shop. The hobby shop only will carry one or two reverse props, but maybe 50 or so regular props.
Furthermore, like i said, my normal (c-clockwise as viewed from the PROPSHAFT END) .61 will run backwards, does not produce oppisite thrust (to make the plane fly in reverse???) it will fly like that, plenty of thrust to fly patterns !!!!!
Something here just ain't right..................
