RE: Engine tests/Range test complete
Bob:
You have a misconception of the fail mode of the EMS/Jomar unit. If the slave engine quits the controller will drive its servo to full, as you would expect. However, if it loses the rpm signal from the master the unit drops out, leaving direct throttle control of the slave.
Bill.
