RE: GP Super Stearman
John, Slaving the top ailerons is using the stick that they provide, it is more scale than using 4 servo's which i believe they also provide the space for. Depending on the servo's you use, i would just use the 2 on the bottom wing and slave them, if you are using standard BB servo's put all 4 in.
