RCU Forums - View Single Post - Servo growling help!
Old 04-21-2004 | 07:44 PM
phread59
Default RE: Servo growling help!
99 trying to force the servo arm with the radio on will cause this. It is normal, the servo is trying to retain the position the radio is telling it to. If it is doing this just sitting there. There is likely some binding in the push-rod or the control surface. You may need to move the clevis's to zero out the contol surface. Good luck.
Mark Shuman
