RCU Forums - View Single Post - Unexpected engine performance.
Old 04-22-2004 | 12:01 PM
  #40
Robrow's Avatar
Robrow
Default RE: Unexpected engine performance.
Sorry to hear you are still struggling with the file upload. I ended up using the usb conection for this and all worked OK, I also used Winzip to make the file as small as possible, this helps when sending and uploading because of server limits.
As this engine is a one-off and no other like it in the world I wanted to see how things went at 140k, particualrly in flight mode before opening the tap more. As you will see from the aerobatic footage there is sufficient power now. Possibly this weekend I may uprate it to 145k to test. I did run it for a long time at 150k during the ground test running program without any problems so hopefully things should be similar in the air.
I'll try later to upload some longer more aerobatic footage.
Rob.
