RCU Forums - View Single Post - Shockflyer Acc??????
Old 04-22-2004 | 04:03 PM
  #65
sport10
Default RE: Shockflyer Acc??????
The info on the Typhoon Micro 6 is false. It in no way draws 20 amps in this application. The specs say it can handle 20 amps though. It pulls around 10 to 11 amps. Work good using either Kokam 340 2S1P packs or Tanic 850 2S1P packs. Make sure to use an high discharge pack. The tanic packs can support 12 amps in 10 to 15 second burst. Use alittle throttle control and every thing will be OK. A good performing setup is too use the micro 6 and a GWS 9x4.7 prop. Just push the prop onto the shaft. There is no need for an prop adapter. There is a guy on Ezone that sell PVC mounts designed to mount the Micro 6 and AXI outrunner motors to the shockflyers. Worth a look.
