Spinner Question........
Most of my airplanes are measured and fitted with an aluminum spinner,i have several plastic ones around that came with ARF kits,
i can't however use these plastic spinners because they are "stepped" on the back or recessed and when i try to use one of these,it will hit the cowl.
What is the best way to take up about a 1/4" on the prop shaft to make these fit?
