RCU Forums - View Single Post - Best method to determine thrust?
Old 04-22-2004 | 08:00 PM
MikeSell's Avatar
MikeSell
Default RE: Best method to determine thrust?
Every engine is slightly differrent from the next, as is every prop. Actual testing is the only accurate way to measure. Many companys are marketing thrust measuring engine stands. You can build your own and use a fish scale to measure thrust. I have found however that my digital fish scale may not be accurate enough to derive very accurat readings.
