RCU Forums - View Single Post - hangar 9 tachometer
Old 04-23-2004 | 05:15 AM
Gryphon
Default RE: hangar 9 tachometer
I've only used a tach a couple of times and was never able to get a good stable reading.
But I do remember reading about checking their calibration.
Since the inside lights run off of 60HZ means 60cycles/sec, and you have 60 seconds in a minute.
Just holding the tach indoors without pointing it at any motors, it should read 3600 RPM.
Make sure you take all your readings outdoor.
I'm no expert but I hope the above helps make sure that your tach is All right.
Good luck.
