RCU Forums - View Single Post - www.Learning 3D step by step - 2
Old 04-23-2004 | 08:04 AM
  #88
AcroJo's Avatar
AcroJo
Default RE: www.Learning 3D step by step - 2
ORIGINAL: pizza
3. you are holding some right aileron to prevent rolling, don't touch the throttle it has already been established
Pizza, at this point, I believe that you must clarify this as an assumption as to the fact that the plane has the torque to rotate. Depending on the engine/prop combo it is not always true. This may eliminate some confusion when transfering your excellent and equally respected advice to real time. Joe
